robertdtr Posted July 17, 2013 Share Posted July 17, 2013 Hello , I have an 07 dt 125 re which has an aftermarket tail tidy with led brake light which I was using along with the standard brake light. The led light would turn off when the brake was applied and the standard would light up like normal so today I decided to disconnect the led light and once I done this and turned on the ignition nothing happened. I'm not very familiar with electrics so any help is appreciated ! Robert. Link to comment Share on other sites More sharing options...
Ttaskmaster Posted July 17, 2013 Share Posted July 17, 2013 I assume each light has two terminals/connectors each? First, reconnect everything and see if the bike will start up. If so, good. If not, shout and we'll look at that. See if you can trace where the LED one is patched into. I'd think it should use the same wires as the main brake light. If not, shout and we'll look at that. Link to comment Share on other sites More sharing options...
robertdtr Posted July 17, 2013 Author Share Posted July 17, 2013 Problem sorted now cheers fuse had blew . The led was wired in with the original brake light but I couldnt get them both to light up when brakes are applied im guessing that the original draws the current away from the led ?? Cheers. Link to comment Share on other sites More sharing options...
