Hi all.
Merry Christmas.
Help please.
I fitted a new chain and sprockets to my Thundercat two weeks ago and i am now getting a whirling noise as i throttle up. I have checked chain tension and used a tape measure to make sure the rear wheel is spaced correctly , so is aligned with the front.
Is this normal with new chain fitments and will it wear away or am i missing something.
Any help would be most welcome as i am now pulling my roots out as i have run out of hair!
Many thanks
Paul aka Thunderass.
Paul.....
Does this noise only occur when you're throttling up? :unsure:
If you can, try rolling down a hill with the motor off to see if you can still hear it?......just to be sure it's coming from the drive chain ;) ......It could be that it's typical run-in noises from a new chain. Also be sure to lube the chain well too.
Hope this helps ;)
Paul.....
Hope this helps ;)
Yamahead.
Thanks for the reply.
I can close the clutch and free wheel down hill and the noise stops.
It only occurs when the throttle is open.
Today though it was worse and i was also getting vibrations through my feet. This was on a motorway.
Any thoughts? :unsure:
Paul.
Hi mate,if your free wheeling it prob wont be as bad
due to not being under tension..
But with it doing since changing chain does seem
to point to that..you dont what a prob with a gearbox.
Did you change front sprocket and its not come loose..
Thanks for the replies.
I checked both sprockets and chain for correct tensions.
All these parts i renewed three weeks ago.
They are well lubed with scottoil, i can spin the rear wheel freely on a stand and the engine sounds sweet when idle or reving.
As soon as i speed up the noise starts. Then as i slow it reduces?
Can this be run in or has anyoen else had faulty sprokets or something.
The parts are all OE.
Be safe.
Thunderass :shrug:
Ps The gears change nice and smooth.
Edited by thunderass
