Hello just joined the noo .
Hi
me handle is charlyfarly just joined your forum tonight , am needing a wee bit of info regarding an engine change from an XV750 1995 to an older XV1100 1990 both engines look identical also the 1100 goes strait in the wireing is all the same in colour and connections till you come to the pick up cable that operates the spark from the fly wheel to the cdi unit , what i need to know is will the pick up from the 750 fit the 1100 and if i did this by removeing the pick up from the 1100 and possible flywheel and changed them from my 750 will it work ok do you know .
many thanks cf
Welcome charly " :jossun: post up in workshop, someone will know...
:wavey: Welcome aboard!
"Charlyfarly" that's showing your age aint it?
I presume from the "Two Ronnies"
