DT175 Kickstart noisy
When i start it and the kick arm returns to its position I get a whirring noise like something catching. If I pull the arm back slightly it goes away. I have had to reposition the arm to rest against the casing to stop the noise. What is going on in there..is a return spring worn? A stopper on the arm would be a quick fix.
Only real way to tell is take it off and have a look inside!! Otherwise your just guessing.
I bet the boss that locates the spring is broken,As Slice said pop it appart to know for sure.
  • 4 weeks later...
Here was the problem..this needs to sit very tight on the kick shaft..the one I had seemed tight but after fitting a new one I saw the difference. Only ZAR20 to replace..kickstart back to normal.
