hi i have a rxs and it seems to be leaking somethink from the bottom left hand side it goes on bth my stands and very faintly on my rear tyre i belive is gear oil
if i take the case of theres this rd that can be pulled out what is that?
i think it maybe comming from that so dunno what seal to buy
or could it be somethink else?
heers andy
Well it will either be two stroke oil or gearbox oil, because petrol evaporates.
Check the screw near the clutch push rod is tight. (between the magneto and clutch arm)
Chances are its the sprocket output shaft seal though.
cheers for reply but ergh pain in the a*** but simple enough
ill have a look tomorrow got 2 days of so cleaning exhaust out and doing other work on it still tryin to figure out my light issue D:
