XJ600 Header pipes
Hello are there any compatible header pipes that fit the xj600 or any close to to the xj pipes that need a bit of fettling . :hyper:
Don't think the 750 or 900 pipes will fit tho as the 600 has a tighter radius on the bends in the pipes, as drewpy says the FZ is a good bet as it has the same engine but you would be wise to check before you buy.
  • 2 months later...
did you have any joy with your pipes i also have an xj600 mine is a pre diversion and i am struggling to find an exhaust i would like to fit a 4 into 2 system if i can
