I have read that all viragos whine when lifting off.
Dropped the oil and clean as a whistle, no nasty filings at all.
Garage happy and said its down to the gears having no play so just ride.
Can anyone confirm this?
A lot of Yamaha's have a gearbox whine especially the shaft drive models.
Sounds like a spaceship, or a bit like Luke Skywalker's speeder-thing?
Perfectly normal. Kinda cool if you like sci-fi, as well.
bike is a low mile minter. no nasty clonks of bangs, just this annoying whine when lifting.
seems to common on some and not on others
Yep, that sound is normal.
Sounds even better on a Dragstar, though!!
However, WTF is up with that rider's gear changes, man?
Is that just the recorder, or is his idle somewhat fuck'ed?
so all seem prone to whining huh? mines the 750 and got a bit worried as not had a shaft drive before.
will do all oils in any case
Yup, I have the whine on my 750 too. It is quite normal for the Virago it is shaft drive after all. Had me worried at first too.
It goes back as far as the TR1 (forerunner of the Virago). My gears whine going up and down :)
so seems nothing to be overly concerned with.
thanks for all the replies.
mine runs fine only whines you when lift off the throttle.
new bike syndrome and worries!!
