December 1, 200519 yr Hi I'm about to fit an alarm to my bike. It says I need to locate the 'positive side of the starter relay'. There are 4 wires to/from the relay. Would it mean the side which 'becmes' live when ignition is turned on or the side which is always live? I presume there is one live going in and one out when the relay is activated? Can anyone help with this please.... Many thanks.
December 3, 200519 yr Moderator Hi I'm about to fit an alarm to my bike. It says I need to locate the 'positive side of the starter relay'. There are 4 wires to/from the relay. Would it mean the side which 'becmes' live when ignition is turned on or the side which is always live? I presume there is one live going in and one out when the relay is activated? Can anyone help with this please.... Many thanks. a relay work by energising a "plunger" across an even thicker wire in order to connect up the starter motor. I would think you only interupt the thinner wires which energise the relay as the current draw for the starter motor will fry the wires as it will be a big current draw. the ignition is usually a separate circuit, unless you mean key switch/ignition to recap thats two thinner wires in 1 positive 1 negative and a common colour in and out for the starter motor I hope i make sense
December 4, 200519 yr Author a relay work by energising a "plunger" across an even thicker wire in order to connect up the starter motor. I would think you only interupt the thinner wires which energise the relay as the current draw for the starter motor will fry the wires as it will be a big current draw. the ignition is usually a separate circuit, unless you mean key switch/ignition to recap thats two thinner wires in 1 positive 1 negative and a common colour in and out for the starter motor I hope i make sense Thankyou.
December 18, 200519 yr Author Thankyou. Hi again. Ok, trouble fitting the remote starter alarm to the bike. I fitted the alarm ok, but its the starter I' having trouble with. The leads from the alarm(blue wire) that is supposed to start the bike works, it supplies a 12 volt signal. The instructios say to connect it to the pos. side of relay. Which I tried. But there are two live and neither of them work. Incidently I thought there would be a wire that becomes live when you press the starter button, but they (there are 4) none of them seem to, except for the two that stay live. Can I connect the live starter wire from the alarm (blue) to the solenoid perhaps? It supplies a live for one second per press of the button. Any elp appreciated. Cheers phatjap
