Posted June 22, 201312 yr Hi, Does anyone know what other 'DT' fuel tanks are the same as the one for a DT175c 1976/77? Thanks
June 22, 201312 yr HI One of the other members was asking the same question, he had a blue DT US 175 twinshock with the 175 c tank which had the square type profile, (like my DT) he had brought a 125 tank that he thought should fit but it wouldnt fit, I cannot find the post, but I recall that he found out that the 125 of the same era as his 175 was the only bike that had this different tank size, he had done some indepth research and had come to the conclusion that the DT175 and the DT100 shared the same tank, but a particular year of 125 did not, If I find the post I will pm you the link, found it: and this: If you do find another and they have a 2nd one PM me my bikes tank is a bit shabby inside,
September 27, 201312 yr I also would like some help as I have a '74 dt175 and recieved a tank from the sates and it doesnt fit, my measurements are 17 3/4 inches from centre of rear bolt hole to the end of front mounting lugs?? Any ideas welcomed!!??
September 27, 201312 yr Sorry and the bike measurements are 16.5 inches from centre to centre !! Thanks
