Posted June 21, 201312 yr HI Peeps, I kind of jumped the gun and forgot to introduce myself yesterday. I own a fazer 52 plate and have been riding for about 6+ years. I come from Aberdeen I am looking for some advice on my bike issue. ----------------- Now I have just bought a Yamaha Fazer 600 52 plate last week and all was fine but my rear left indicator went last night. Now I have changed the bulbs and tested it again but still not luck. Does anyone have a rough idea what maybe wrong? I guess it is wiring somewhere but don't have a clue where to start. Every other indicator works fine bar the left rear. Now I did stall the bike and very quickly started it and then I noticed the indicator was blown. I am not sure if it had just gone prior to that or not. Now I have looked at the wiring diagrams but got lost straight away. Any help would be appreciated. Regards, G
June 21, 201312 yr following the indicator wiring shouldn't be that hard, swap it out for the inidicator from the right and you will find out if its the actual indicator, or something before that. Have you checked the connections?
June 21, 201312 yr Buy a multi meter, there cheap. chances its a bad earth, un bolt it ,clean it and remount it,
June 23, 201312 yr Author Is it a separate fuse per indicator??? All the rest are working correctly G
June 23, 201312 yr eliminate the obvious by putting a bulb that you know works into the one that doesn't.
June 26, 201312 yr Author Done that already Mike1949. So the wire must be disconnected somehow. I just hate looking at wiring diagrams
