November 23, 200519 yr I bought my first bike (250 Virago) a couple of months ago and took it in for the 600 mile servicing and was I shocked when they gave me the bill: $190! I was thinking it would be more in line with taking a car in for a lube, oil, filter. Obviously, I was mistaken. Does $190 sound right? If so, I think I'll be taking a crash course in motorcycle maintenance.
November 23, 200519 yr Moderator Prime example of why I don't take my bikes anywhere for service! Do it all myself & save Big Bux Plus, the more you learn about your own bike, the easier it is to troubleshoot when something goes wrong
November 24, 200519 yr Author Thanks. I agree, if you're going to get into riding you'd better learn something about taking care of your bike, or have a big wallet. Sense I don't have the latter I'll start learning. By the way, as most of you probably know, the big cost was the labor for taking engine components apart to check the valves. And surprise! (with only 600 miles on the bike) the valves were normal and did not need adjusting. Possibly a Freudian slip misspelling the word since; since I had little good sense taking my Virago in for servicing
November 28, 200519 yr Moderator And surprise! (with only 600 miles on the bike) the valves were normal and did not need adjusting. You'd be surprised just how far you can go before you actually have to adjust those valves! If you keep your oil changed frequently & DON'T over-rev the motor too much.....they'll easily go a few thou before needing adjusting. I recall getting well over 15k on my old Seca550 before actually adjusting 'em.
November 30, 200519 yr I've never had to adjust the valves (or don't feel I need too ) on my '81 Yamaha XJ which is now at over 90,000mile and has never had any actual engine work ...yet Ooh lets see if I can reach that 100,000 mile barrier on the Original (untouched) Engine, Gearbox and clutch ...
