DT175MX Speedo light issue
Hi Ladies and Gents.
For some reason when I change my bike into gear and the neutral light goes off, so does the speedo backlight. Have done a bit of head scratching but not sure why it is doing this.
Sent from my GT-I9505 using Tapatalk 4 Beta
Is it possible that the oil warning light bulb holder has been put in where the speedo backlight bulb holder should be and vice versa if that makes sense. The oil warning light should come on with the neutral light and both go out when put into gear.
Thats is possible. Will check it out when I get home. Thanks, I had no idea the oil light should be on with the neutral light.
Sorted. Thanks heaps Tone.
