need advice on an engine swap
Hey there,
At the moment my bike is off the road because my gear box is broken. Anyone know any issues with switching an engine for a ybr 125, mines a 55 plate, is it ok to swith with say a 2010 engine???? Any help would be brilliant :)
hey hippy I know your new and the sub heading for the bar is open to interpretation but this is really a subject for the workshop forum
you'll get better reply's there mate
also your only 17 WTF you doin in a bar lol
that's OK wasn't able to answer your Q But I think it would be fine except for maybe a few electrics
the'res plenty of ybr owners on here who will know for sure
If I'm right your 55 plate is a carb model and the 2010 bikes are fuel injected but I'm sure everything else is the same. Maybe more electrical stuff but a look in the hanes manual for the year of the bike engine you are going to use could help
It must be cheaper and more sense to just change the gearbox components, after all it just means removing the old gearbox internals and replace with the same from another bike? not sure what the procedure is but if cost is an issue (which it is for most of us) then do the cheaper thing. Plus if you go to a newer engine then as above injection versus carb conversion can be a nightmare just getting the wiring right, not for me to say really but this is a case of LESS IS MORE.
