June 14, 201312 yr Hello people I was told by a person on YouTube that if you earthed a wire behind the speedo your top end speed will be faster and I wanted to try it out, so had a look and there is a few wires there but didn't know what one it was so if anyone knows what wire I should be looking for could you help me out please Cheers Lewis
June 15, 201312 yr Author Dose it's matter what year it is mate as I have the new shape and ant got a rev clock Cheers
June 15, 201312 yr Dose it's matter what year it is mate as I have the new shape and ant got a rev clock Cheers I don't know much about the DT's but it does say *100% certain on 2004 + models* so i would think it will work. Good luck!
June 22, 201312 yr There's a four pin connecting block with four wires going in and only three coming out, the one that doesn't go to anything should be black with a green line down it, clip this wire off and connect it to the frame
June 28, 201312 yr Author We're are the wires please? Are they be hind the speedo clock as haven't found the one a one to put to the frame Thanks
June 30, 201312 yr The connector block is behind the speedo, grouped with a load of other cables in a rubber boot. You'll have to remove the front headlight and cowl to get to them.
June 30, 201312 yr Author thanks finnerz89 ill remove it and have a look i know what rubber boot your on about so should be able to sort it cheers
July 5, 201312 yr As long as it's a nice clean connection it shouldn't matter. Radiator mounting bolt is ok, or if you're good with a soldering iron you could connect it to your headlamp earth. Basically anything that leads back to the neutral on the battery=earth
