June 17, 201313 yr Great quality! However, the camera seems to be very shaky. I can only assume a few things here; 1) you have a bobblehead, 2) roads are terrible, 3) the camera is slack causing it to bounce up/down/left/right slightly. I think that JVC camera has a stabiliser function built in, maybe try turning that on to see if it makes a difference. I actually think it might be 3, you can clearly see the camera isn't exactly moving with the helmet. But, that might also be because of the wide angle effect.
June 18, 201313 yr yes, the camera have the function but I don`t set anything in first video, I just activate DIS now and I will make a new video later.
