cathunter Posted June 9, 2013 Share Posted June 9, 2013 hi my girlfriend has got a dt 125 r what she loves to ride but its a bit too high for her. when she rides she on tip toes .would it make it any lower if i adjusted the preload on the monoshock if not is there any way to drop it by about an inch any help would be goog cheers 1 Link to comment Share on other sites More sharing options...
Taffman92 Posted June 10, 2013 Share Posted June 10, 2013 you can buy a lowering kit for it , looks like this, I think the longer it is the lower the bike sits and the shorter the higher the bike sits and its fitted just below the swing arm Link to comment Share on other sites More sharing options...
cathunter Posted June 13, 2013 Author Share Posted June 13, 2013 cheers dude i will look in to the lowering kit thanks again Link to comment Share on other sites More sharing options...
Taffman92 Posted June 13, 2013 Share Posted June 13, 2013 no worries Link to comment Share on other sites More sharing options...
dt502001 Posted June 13, 2013 Share Posted June 13, 2013 Hey just rember to lower the front as well,, the same height as the rear or you will change the steering angle.And it will handle like crap. silde the forks up and then find the right links to lower the rear the same Link to comment Share on other sites More sharing options...
cathunter Posted June 17, 2013 Author Share Posted June 17, 2013 hey thanks dude hadnt thought about lowering the forks thanks again Link to comment Share on other sites More sharing options...
NEV Posted June 17, 2013 Share Posted June 17, 2013 If I remember rightly, the DT125X forks are shorter than the standard DT125R ones. Link to comment Share on other sites More sharing options...
