Hi all
I have a TZR125 and have changed the (right hand) crank seal but it still uses the gearbox oil. So far I have tried genuine seals and pattern (mounted the right way round) - also put a new spacer with 'O' ring on the outer edge.
All to date still has not stopped engine using the oil from the gearbox aswell - recently got another engine (complete) as I want one to tune up slightly - that does exactly the same.
Any ideas from anyone - getting annoyed with it now !!!
Have split the cases and made sure the seal between them is good also !!! - and checked the vent is clear so its not pressure building with the box etc
Cheers
Ray
