iv been looking to get an aftermarket CDI finally
you cant directly buy one for an xt (or ybr)
but you can get one for the ttr 125 but non adjustable/ programable
with preset timing curve
same engine, stator and connection
recently ive learnt that the raptor 125 shares the same engine
so I get searching and reading
and found it only has a 6 pin cdi (stock 7)
im guessing this is due to it not needing a side stand switch
so a lil rewiring would be needed
but you can get procom adjustable cdi 9 settings
top one removeing all restriction off top end revs
but then looking through people would have tuned up raptor 125s
have used the raptor 450 cdi this you can completely adjust the CDI digitally
but the one connector block on it is the same im guessing the other is for water cooling
so to put it in short is it to far fetched to try fit a raptor 450 Digitally re-pro CDI
to a xt 125
I will be buying the ttr 125s CDI (AMR Stage 3)
and if I come across a 2nd hand yfz 450 performace Cdi on ebay
im tempted to give it a go
How much are the CDI's? Unless they're expensive might be a worth a gamble.
the ttr AMR stage3 £100 + AMR monster spark coil £40
http://www.amrracing.com/index.php?l=product_detail&p=117
there are other makes mainly procom around the 100 mark
raptor 125 £100 again but is adjustable not reprogrammable
http://www.ebay.co.uk/itm/Yamaha-Raptor-125-Procom-Rev-Box-CDI-Hi-Performance-/111012521673?pt=Motors_ATV_Parts_Accessories&hash=item19d8dca6c9
raptor 450 £130 at a guestimate im shit with converting from £ - $
http://www.electrosport.com/atvs/yamaha/yamaha-atv-cdi-pe-c-ay450-a.html
if you have a look on google images u can find the pictures of the connecter
you can ignore the 450s smaller connecter
its for the diode above the cdi on the xt just built in
anyone out there pro on these sort of things
also can someone move this topic to work shop please
  • 9 months later...
Hello did you find out if any of these cdi's worked on the xt125 because I've been looking at ttr125 cdi's for my xt125r
