Posted May 19, 201311 yr Got all of the aerox back together went to go for a test ride and there's no power, does not want to move with me on it, but if I lift the back wheel it will spin, could this be the carb setup been wrong, or something else? It did have a 70 kit on before the piston and cylinder went, just fitted a standard 50cc one now tho, any ideas would be much appreciated, desperatly need it fixed
May 19, 201311 yr Moderator get the carb back to standard specs including the airbox. should work as it should then
May 19, 201311 yr Author I don't know what jet is in at the minute I'm just geussin it isn't standard with havin a 70 kit on previously but still has standard air box, so standard size jet should sort the problem out?
May 19, 201311 yr If you're running a carb that is set up for a 70cc but with a 50cc engine it will be overfueling, resulting in the lack of power, check the colour of your spark plug, should be a chocolatey brown colour on the end although i suspect yours is running rich so it may look black and sooty
May 19, 201311 yr Author I had it on idle for about 20 minutes took it out and it was a really dark choclaty brown, close to a black, I will pop to the dealers on tuesday and see if they have any jets in stock, fingers crossd they do and I can get it running thanks for the advice lads, will update when I get new jets
May 20, 201311 yr Author would both the main and pilot jet of been changed when it got the 70cc kit on it? so i would have to replace both of these? or just replace the main jet?
