Posted May 10, 201312 yr So my speedo has stopped working on my xt125x and I can't seem to find a new cable for it anywhere on the net :S Is there such thing or is the fault lying somewhere else? Everything else like RPM is reading fine it's just my speed that isn't showing. It's reading 0mph constantly. ANY HELP!? EDIT: I've taken the cable all apart that leads from my wheel to my speedometer, and it's nothing like has been described, it's like 4 different coloured wires that lead to a connector that connects to another set of wires that go to my main console :/
May 10, 201312 yr Remove the cable from the speedo and turn the front wheel the inner should turn ,if not remove the cable at the wheel and check the cable inner is not in 2 pieces and hook up the cable to speedo if in 1 piece and turn inner by hand if speedo works then the drive in the front wheel is not working.If not speedo is broken If you had the front wheel off did you align the drive to the wheel when reinstalling the wheel?
May 10, 201312 yr Author Remove the cable from the speedo and turn the front wheel the inner should turn ,if not remove the cable at the wheel and check the cable inner is not in 2 pieces and hook up the cable to speedo if in 1 piece and turn inner by hand if speedo works then the drive in the front wheel is not working.If not speedo is broken If you had the front wheel off did you align the drive to the wheel when reinstalling the wheel? I've not had my front wheel off at all as far as I can remember, I hope the speedo isn't broken because that will be expensive :/
May 21, 201312 yr Author Did you ever try anything I suggested and if so what did you find? Look up at the original post, I've posted an EDIT of what I tried and what I found
May 21, 201312 yr I am the XT 125 speedo expert. Your speedo is fucked just buy a new one. The digitech ones are really good. Do a forum search and refer to my previous threads.
