Fork oil capacity and spec for xt 125 r 2007
Hello there mates.i'm new at forum.i m planning to change my fork oil and fork seals.i wanna know the level of the fork oil.i own 2007 xt 125 r.i found a service manuel which says it needs 285 mm oil but its a 2005 year service manuel and i wonder is its the same level for 2007 models cause 2007 and 2009 models front suspension travel differs.
bottomline : would someone tell me the exact level of fork oil for 2007 xt 125 r and is it 10w or 5w oil thanks very much.Regards!
i have the same thing to do. i got 10W oil and will be using the same amount you stated.
i bought 5w fork oil.dunno if it will be too soft and jumpy.fixya website says it requires 280mls.still dont have proper answer
Already bought the fork seals and oil,would someone tell the level of the oil per leg.Regards!
I think you'd be well-advised to add an introduction in the new member section. You might get more help once you let everyone know a little about you. :)
Welcome aboard. :wavey:
  • 1 month later...
personally I put 250ml in each fork 10w
