So, I'm coming here again to ask you all, who have been in touch with Yamaha DT 125.
Are someone able to filma a video - how to destruct rev limiter? Because, I did it, but I think that I have not done it properly. My bike still not run freely, and max speed is lower than in start, when I bought my bike (top speed then 120km/h) now max 95km/h, when full trothle in 5th gear (6th has no power).
Where else is any limiter in bike what I could do, destruct, eliminate w/o buying something?
I have new crankshalf, fully cleaned carb and air filter. No succes.
Help me.
My bike - yamaha dtx 125 2006. Doma silincer, hgs pipe. Mikumi carb. Stock crankshalf, air filter, cylinder, piston.
Where is my bike problem?
Fuel tank , or petcock,,, take off pipe and see if good flow,,, :eusa_think:
Ok. I will take a look. Some other ideas why last gear has no power? Can someone make video how to correctly destruct rev limiter?
What I can fill in clutch case? Whose oils are compatible with 2 stroke engine clutch? 10w40 should be ok?
