The stock mirrors give me a great view....of my elbows, so I'm looking for a replacement, but I don't know if mirrors from any other model will fit. Yamaha has been less than forthcoming with this info. Does anybody know?
Thanks,
David.
It really is a problem, the YPVS range use the same mirrors and they are just as bad.
If it's style you want then you'll have to stick with them but take the 'perch should accept any 10mm rhs threaded mirror.
The 'perch should accept any 10mm rhs threaded mirror.
That's what I was thinkin'........I've swapped mirors from XJ's to RD's without a prob before.
Just have to look around for just the right bend to get that desired view around your elbows ;)
