xvs 125 clerance...
Thornhorn
This post is 4154 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi Guys, did anyone ever noticed that the front cylinder exaust sounds very different from the rear cylinder?
Also while adjusting the intake valves clearance , I forgot to take out the sparks and noticed that the compression (when moving the crankshaft) was escaping trough the timing sprocket case is this normal? Should I be able to move the camshaft without removing the plugs? Sorry for these questions. but I'm not used to 4 stroke engines.
There's a theory that when balancing the cyclinders, the front one should run a little hotter than the rear one, as the latter gets less cooling airflow... but it's just a theory. Not something I've ever tried.
