May 2, 201312 yr Look on the right hand side of that page, the last link you posted, it shows all other models with compatable parts, if not in stock, look in Ebay once you know other models you can use
May 3, 201312 yr Author Okey, this is really sad, because no one have that Kick idle. No stock in europe or japan. Where could i get it ? Someone have full sizes of this part, maybe i can make it by myself.
May 3, 201312 yr Author Is this the gear im searching for - http://www.ebay.co.uk/itm/38986-Yamaha-TZR125-4DL-91-95-Starter-Idle-Gear-/300862704819?pt=UK_Motorcycle_Parts_13&hash=item460cd08cb3 ? Or this - http://www.ebay.co.uk/itm/Yamaha-YFS-200-Blaster-YFS200-Used-Engine-Kickstart-Idle-Gear-1989-BDK-/150915680656?pt=Motorcycles_Parts_Accessories&hash=item2323468990 Have 29 teeths.
May 3, 201312 yr Author http://www.ebay.co.uk/itm/YAMAHA-YFS-200-DT125-LC-200-WR-200-ZAHNRAD-F-KICKSTARTER-GEAR-KICK-10V-15651-00-/190816941296?pt=Motorrad_Kraftradteile&hash=item2c6d9374f0 FOUND IT!!!! Someone please tell me this is right !? Ever numbers are the same
May 3, 201312 yr It looks like the right one Emilz, but at 39 euros, I'd be looking at buying an old bottom end if I could, and taking one out of that.
May 21, 201312 yr Author UPDATE. Okey, now i put all in, all is correctly in thouse spots, and i think its working ... BUT - i thought that than my old bikes kick start leaver is going to fit, yeah and it does. I get it on, BUT it is unable to do full kick, because stops at clutch corbel, because my leaver has spot for bolts in that spot, so i cant do full kick ... So I am searching for that leaver. From whitch bikes it is going to fit (diameter of kick mehanism outside of case ~16,5 mm) ... Orginal costs, cheapest over 50 pounds, I think thats too much for leaver after i bought mehanism for 16 pounds ... So - Any alternitives???
