Rectifier wiring on project mong
Hiya peeps
Have started work on project mong and have discovered that there are 3 white coloured cables coming from the charging side of the engine going to the rectifier, however the cables have been cut and i dont know which ones fit where.
as i understand it, the rectifier is a series of diodes which will only allow certain parts of the AC circuit to flow (converting the 3 phases of AC into one flat DC sinewave), so does it matter which phase goes to which diode on the rectifier?, hopefully i can get this sorted later tonight and have it running by tomorrow maybe :hyper:
