May 20, 201313 yr Author You probably need a puller to get it off the con rod if it will not just slide out, it MIGHT be possible to heat it and then give it a whack with a drift but there is always the potential to damage something else along the way if you do that unless you are really careful, as your splitting the engine anyway why not wait till you have it apart and then take it off of the crankshaft and deal with it in a vice rather than trying to sod about with it attached to the engine? That seems to be the best idea I can come up with for the moment maybe others will have a better idea. Just a thought why not just junk the con rod & piston altogether and fit new when you have it all in bits? Good luck Fakhir. You are right, I will probably get a new connecting rod and piston. Thanks a lot
June 26, 201313 yr Author Week 4 updates (26-June-2013)Hey, I hope all of you are doing fantastic. Well it's been a while since I posted anything on the forum, been a bit busy. This time I was successfully able to tear apart the exterior engine hull and disassemble gear, kick and clutch assembly. Right now stuck with the cam shaft and piston assembly. Next time I will try to completely open up the remaining engine parts. Sorry no descriptions on the pictures this time. I will add those later on. Enjoy !!!
June 26, 201313 yr Author IMP: Following pictures (and movies) are taken by my brother using his awesome DSLR 60D camera. You can check out his other non-related but super cool pics and videos on his personal blog:http://farhanshaheen.wordpress.comand here:http://www.flickr.com/photos/popat
June 26, 201313 yr Author Finally borrowed a drill:My good old trusty point and shoot camera: YB100 manual. Keep it handy at all times !!!
June 26, 201313 yr Author Videos: (720p HD) It is highly recommended that you watch these videos in fullscreen HD mode. They've got pretty high resolution. http://www.flickr.com/photos/fakhir/9138629640/ http://www.flickr.com/photos/fakhir/9136714157/ http://www.flickr.com/photos/fakhir/9137060105/ http://www.flickr.com/photos/fakhir/9136817903/
June 26, 201313 yr Author Summary:Well this is it for now. I hope you enjoyed the pictures and videos. I've opened up and disassembled clutch, gear and kick assemblies. Generator assembly has also been drilled out. Next time I will try to further rip up the engine covers and hopefully gain access to the entire camshaft assembly. Stay tuned for the next episode. Bye for now !!!
June 26, 201313 yr Eeek... I don't like spiders. Looks like you've been busy with the drilling. Not very fun... but it'll be so rewarding when you finish her.
June 26, 201313 yr Hi Fakhir, Glad your back and got some things done on your old bike. It seems you have most of it in hand now so well done and not long now till your riding it, liked the Videos by the way the photos were a bit confusing at first but got there in the end.
June 26, 201313 yr Author Hi Fakhir, Glad your back and got some things done on your old bike. It seems you have most of it in hand now so well done and not long now till your riding it, liked the Videos by the way the photos were a bit confusing at first but got there in the end. The real challenge now is to clean it
June 27, 201313 yr Don't know if you have "GUNK" in Pakistan? but if you do that will clean your oily bit's !!! Any degreaser really will do the job as long as your careful not to get it in your eyes and you will stink afterwards. Just DON'T use petrol/gasoline works most of the time but has a habit of blowing up and setting fire to your workshop.
