Ever since ive had it, it will never tick over cold when i take the choke off itll tick over fine
Uh?
Just to clarify.
Do you need to use choke to actually start the bike? Then once its running you take the choke off and she idles ok. If a little uncertain till she warms up.
If thats the case it sounds about right. Choke on a 2 stroke is really just to get it running.
yeah thats what happens ill use the choke to get it started ill have to keep it on for a bit to warm her up then ill take it off and itll idle fine
I keep choke on for about 5 mins, adjust idle thumb screw on carb so she revs about 2k rpm
Choke off the adjust idle back to 1.5k rpm...
Sometimes they meff a little blip of throttle after turning choke off.
Ken
Sounds perfect,,,,, just keep it on for a bit longer
Bit confusing this, everybody says keep the choke on longer, but he says wont tick over with choke on.. :eusa_think:
The revs should be high with choke on,[2k] and as the revs drop, take the choke off,
his first post says " idles fine wen off choke," meaning its dieing with choke on, [ i think thatswhat he means] if so , sounds a bit ritch
check air screw,[ turns out] ,,, :spin2:
