Dt wont tick over cold
ahaywood93
This post is 4217 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Uh?
Just to clarify.
Do you need to use choke to actually start the bike? Then once its running you take the choke off and she idles ok. If a little uncertain till she warms up.
If thats the case it sounds about right. Choke on a 2 stroke is really just to get it running.
Link to comment
Share on other sites
I keep choke on for about 5 mins, adjust idle thumb screw on carb so she revs about 2k rpm
Choke off the adjust idle back to 1.5k rpm...
Sometimes they meff a little blip of throttle after turning choke off.
Ken
Link to comment
yeah thats what happens ill use the choke to get it started ill have to keep it on for a bit to warm her up then ill take it off and itll idle fine
Sounds perfect,,,,, just keep it on for a bit longer
Link to comment
Bit confusing this, everybody says keep the choke on longer, but he says wont tick over with choke on.. :eusa_think:
The revs should be high with choke on,[2k] and as the revs drop, take the choke off,
his first post says " idles fine wen off choke," meaning its dieing with choke on, [ i think thatswhat he means] if so , sounds a bit ritch
check air screw,[ turns out] ,,, :spin2:
Link to comment
  • Recently Browsing
