Andrewh1 Posted April 21, 2013 Share Posted April 21, 2013 Hey there fellow Yammers. Quicky for you which will probably make me sound a bit daft (I am). I want to change the chain and sprockets on my Thundercat and fancied going down a tooth at the front for obvioius reasons. Thing is, I dont know how many teeth there are to start. Plus when you buy a bike specific kit it would come with the standard sprockets. Any suggestions? Thanks folks, Andy 1 Link to comment Share on other sites More sharing options...
blackhat250 Posted April 21, 2013 Share Posted April 21, 2013 Aye andre" the big advantage of buying the kit is" the sprockets will be the same pitch as chain,, sellers will sell single fronts, then you find they"re a diffferent pitch, i v even seen sprockets listed on ebay for the model , and sending wrong spline size,, your going down 1 tooth " that = wheelies and poor fuel consumption,, Link to comment Share on other sites More sharing options...
YPVS TONE Posted April 21, 2013 Share Posted April 21, 2013 Certain the standard sprockets for the Thndercat are 15 Tooth Front and 47 Tooth Rear but you may want to remove the front sprocket cover to confirm. A lot of aftermarket suppliers will give you the option of going up or down from standard on the front sprocket. Link to comment Share on other sites More sharing options...
neversaydie Posted April 21, 2013 Share Posted April 21, 2013 Simples Remove the sprocket cover and count the number of teeth. Mark the 1st one so you dont count twice Parts suppliers like Wemoto will sell individual sprockets with more and less teeth for front and rear. Bear in mind that you may have to shorten/lengthen the chain to suit Link to comment Share on other sites More sharing options...
Andrewh1 Posted April 21, 2013 Author Share Posted April 21, 2013 Blackhat250 what do you mean when you say 'pitch'? I have seen this when looking on eBay etc and not being the most mechanically minded means I'm a bit clueless on this one. Thanks Link to comment Share on other sites More sharing options...
Preload Posted April 21, 2013 Share Posted April 21, 2013 If you want more acceleration its always better to increase the rear sprocket size, fitting a smaller front sprocket increases the loading on the chain. Link to comment Share on other sites More sharing options...
