YBR 125 Indicators won't work
All the indicators will not work when I try them there's a click but nothing else any ideas where to start ? I have looked at all the bulbs and they are all fine. They worked fine last night when I came home from work and at 05:30 this morning nothing ?
Its unlikely that all the bulbs will have gone. check the fuse. Anything else not working?
Weak battery?
Everything else works , and the bike starts first time
Check the connectors on the relay, if your getting a click then sounds like the relay is working but might not be transferring the power. If the connectors are all ok, might be best to change said relay and see how that goes
Changed relay and all is well thank you Noise for your help :)
And every one else for your info
Glad to be of help. Always best to check the cheap things. One because they are cheap and brake easy and two because.......um.......there cheap to replace lol
