YBR 125 Indicators won't work
paul-666
This post is 4163 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
All the indicators will not work when I try them there's a click but nothing else any ideas where to start ? I have looked at all the bulbs and they are all fine. They worked fine last night when I came home from work and at 05:30 this morning nothing ?
Weak battery?
Check the connectors on the relay, if your getting a click then sounds like the relay is working but might not be transferring the power. If the connectors are all ok, might be best to change said relay and see how that goes
Glad to be of help. Always best to check the cheap things. One because they are cheap and brake easy and two because.......um.......there cheap to replace lol
