April 21, 201313 yr All the indicators will not work when I try them there's a click but nothing else any ideas where to start ? I have looked at all the bulbs and they are all fine. They worked fine last night when I came home from work and at 05:30 this morning nothing ?
April 21, 201313 yr Its unlikely that all the bulbs will have gone. check the fuse. Anything else not working?
April 22, 201313 yr Check the connectors on the relay, if your getting a click then sounds like the relay is working but might not be transferring the power. If the connectors are all ok, might be best to change said relay and see how that goes
April 27, 201313 yr Glad to be of help. Always best to check the cheap things. One because they are cheap and brake easy and two because.......um.......there cheap to replace lol
