yzf 600 cuts out when put in gear
my yzf 600 has just started cutting out when put in gear changed side stand switch but no different any advise greatly appreciated
Have you tested the new switch? The stand is definitely going all the way up and engaging the switch? Have you tested this with a multimeter? Or just bypass the switch and see if it's still doing it. Check that the shift rod isn't touching the switch. It really sounds like a side stand issue.
