TZR 125 Spluttering Problem
Firthy
This post is 4240 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Because with the valve pinned wide open the carb settings are wrong. Your going to have to put up with it.
At low rpm it should be flat and horrible to ride in traffic then at around 6k it should light up and make like the starship enterprise going to warp. Seriously the power will come in in a big wheelie inducing wallop. Its brilliant.
Its a bit of a guess.
Back in the day the greace monkeys (me included) were sticking jets upto 250 in for proper flat out screaming.
After taking the restrictions out. If im honest we ruined more than most as we screwed the power right up and caned em.
If yours takes off at 7 cleanly leave well alone and keep a weather eye on the plug colour.
i cant,figure out why,its fouling them
Might be sucking gear oil thru R/H crankseal ,, :eusa_think: ,, check your oil level....
