This post is 4314 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
no doubt some day it will be like the DT50s... i practically gave mine away for £350 three years ago, and now they are going for £600+ for one like mine :(
Once I've upgraded it's getting put at the back of a garage and forgotten about.
oh thats not all though, you've got to keep it clean to keep the rust and corrosion away, the battery will sulphate and become useless, the tank will rust from the inside if you dont leave it full of fuel, but if you leave fuel in the carb it may turn into varnish like my XJ carbs did.
even if its parked up, to keep it good you've got to run it up every now and then to keep everything in working order ;)
