dt 125 brake caliper
hi folks, wondering if anyone would no if a rear brake caliper of an 05 dt fit onto the 2000 dtr model..?? as my brothers has seized tryed changing pads and the piston is stuck and wont release.. so think i need a new one/second hand one.. just found 1 for 40 but its off the above model so any help or any one with the nohow ??cheers .....dtluke :eusa_shifty:
Why not just sort the one you've got - sounds like it just needs a cleanup of the piston and new seals. Worst case scenario is new piston as well - stainless steel one with seals about £35 from WEMoto.
To get the old piston out, just refit the caliper, bleed the brake and use the hydraulics to push it out - or you could fit a bleed nipple adapter to a grease gun and pump grease into the caliper, that should shift the bugger!
