April 6, 201312 yr Hi all I'm getting a loudish squeak on my front brake disc it's fine when I slow down in there's properly but when coming to a quicker stop it squeaks any ideas please.
April 6, 201312 yr Moderator all brake disks squeal, bit of coppaslip between the pads and brake piston and a thorough clean, should change the harmonics back to inaudible levels
April 6, 201312 yr At least it's not as bad as the navvy who had a squeaky wheel on his wheelbarrow. He took it to the building site foreman and complained that every time he pushed his wheelbarrow it went squeak, squeak,squeak,squeak,squeak. "you're fired" said the foreman. "Why" said the navvy. "Because" said the foreman, it should be going, squeak,squeak,squeak,squeak,squeak,squeak,squeak,squeak,squeak,squeak,
