April 5, 201313 yr HI there does anyone know weather the ignition coils from a FJ1200 3cv 1990 will fit a FJ1200 3xw 1992 ? If not does any one know of pattern parts ?
April 6, 201313 yr I run a fj1200 1tx im pretty sure all the FJ1200 models use the same coil packs. I also run an XJR1300 that appears to have the same coil pack as well. Hope that helps
April 6, 201313 yr Author I ordered a set of genuine second hand ones of Flea bay, hopefully it will resolve my rough running issues !! Thanks for the help .
