FJ 1200 Ignition Coils
HI there does anyone know weather the ignition coils from a FJ1200 3cv 1990 will fit a FJ1200 3xw 1992 ?
If not does any one know of pattern parts ?
don't know if there the same. try www.wemoto.com £34 hope this helps
I run a fj1200 1tx im pretty sure all the FJ1200 models use the same coil packs. I also run an XJR1300 that appears to have the same coil pack as well. Hope that helps
I ordered a set of genuine second hand ones of Flea bay, hopefully it will resolve my rough running issues !! Thanks for the help .
:spin2:
Did the new coils solve the problem? or is it carb. balance or plugs?
