cutting out
the tzr125 i own now keeps cutting out whilst i am riding it does any one know what could cause this
check the petrol tap assy think the tzr had a diaphram type ie no sucktion no petrol look 4 a tube that goes from the inlet manifold to the tank :D check 4 a blockage or a kink :D
cheers i'll check it tomorrow
could be a slightly loose ignition switch. does it sometimes to my 350
i ve tried both of the ideas that were posted but the ignition switch was tight and there was no blockage in the pipes, i've had the coil tested and that was ok any other ideas cheers
try the 2 fule filters if not its a carb prob
Very, very gently rub your fusebox clips with sandpaper and try new fuses.
i can't seem to find the fuse box were would it be
