Aerox keeps cutting out and very slow
I was out on my moped then suddenly the engine cut out. I got it started again but it cut again. While it is running it struggles to reach 30mph when usually it gets up to 50 mph plus. Anyone know what could be the problem.
Yea mate got half a tank. Dont think it's fuel as it has lack of power and speed.
blocked fuel filter????
restricting fuel flow, and blocking up so scoot dies.
did it just cut out or did it splutter and die?
First thing to do would be pull the spark plug and see what coulor it is. And pop in a new one,and check the air filter
iv checked the fuel line from the tank to the carb and its all going through well. I think they may be a problem with the fuel going through the carb. As when I leave if for an hour or 2 , its start and dive fine for about 10mins .I think this is because it has had time to soak through. anyone know where to go from here ?
