March 30, 201312 yr HI all have just bought after market headlight for Dragstar, Looks great but problem is, when switch is at dip, light is main beam. When switch to main beam, light is dipped. Have tried changing wires over but still same. Any Ideas folks? ......
March 30, 201312 yr At the risk of sounding completely dumb... is it possible to put the lamp in upside down? Going to hide now
April 1, 201312 yr Swap the wires from switch end or from the connector socket in between...it aint a big issue mate... You may use the wiring diagram, focused onto color codes, in the service manual...
May 1, 201312 yr Author Tried everything, nothing worked. Returned headlight got replacment, works fine now.
