XV 125 needs choke to start, doesnt hold on at idle.....
Hi Guys,
My XV125 requires me to choke when starting...this is not a necessity with my other xv125, and was not the case with the subject xv125 earlier..
Once started, I can rev only at high RPM, At low RPM engine gets low and low till it stops..
But when engine goes to stop if I pull the choke it revs up again...
There's no air leak at carb joint, am sure about it...
As everybody suggested I set Idle screw , doesnt seem to alter the situation..
Am wondering someone , may be at the garaj, someone has toyed with the mixture screw? The reason why I think so is, when engine goes to die at idle irrespective of my acceleration if I pull choke engine revs again, I can rev engine with choke jst like I would with accelerator...
Please read carefully and help me solve this...sounds like carb is bad..? Thank u all!
Blocked idle circuit thats all.
Just needs a clean.
Really?? Buddy I cleaned the whole carb with ABRO carb and choke cleaner....right after cleaning even this stayed same...
Please highlight the areas I should look into..thanks
