March 29, 201312 yr well, I finally got it running well but now the rear shock is too soft. I'm 175Lb and it's way too easy to bottom. anyone have any suggestions on rebuild replace? thanks, Jim
March 29, 201312 yr Moderator Odd. Same weight as me. Maybe the spring has gone soft. When does it bottom out.
March 29, 201312 yr Moderator Odd. Same weight as me. Maybe the spring has gone soft. When does it bottom out. yeah, never thought about that, quite a fair bit lighter than me and mine hasnt any issues even with camping gear piled high at the back. I wonder if you have lost your pressurisation (Nitrogen) Jim ?
March 30, 201312 yr I have a rare yamaha release note that was issued to dealers when monoshocks were brought in in '78. It states that you can.get a softer spring, and a stiffer spring. From memory I.think the stiffer spring is shared with the RD 400. I am in the.process of moving so will clarify when I can. On a standard spring without a jackup kit it's not uncommon for my lardy arse to introduce the wheel to the back mudguard. I am pushing 15 stone mind...
April 5, 201312 yr ok i lied Sorry I must have had RD's on the brain. Which is daft because the rd400 was a twin shock. There was an optional spring for the dt175mx, and if this wasnt stiff enough the next one up was a standard spring from a DT250/400 I will post some pics of my source when Ive moved, Ed
