Got the 83 Seca900 home today and my have my work cut out for me. Petcock is missing altogether, are these generic with 650 750 etc. look the same, bolt holes 45mm apart. I need to clean tank, change oil/filter, install a petcock then I'll see if this beast is worth keeping. Looks like a project.
Wow, come on guys , little help for a newbie. simple yes no will do. Fuel sending unit is missing all together also along with covers for battery and air filter need to be found. Did use search engine with no luck !!!
Honestly I don't think anyone knows for sure you had enough views,try running the part #'s against eachother.
As far as the parts you need try soniccycle.com 1-519-659-7833 the web site is crap so you have to actualy ask for what your looking for he has tons more than whats on the site.He has bins full of petcocks and probably the rest of what you need.
