yamaha dt neutral light stays on
ahaywood93
This post is 4199 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
The neutral wire is earthed somewhere on something. Or the switch is stuck.
Dissconect the switch and you will know
The switch is self grounding,only 1 wire comming out of it right?
did you pull it out to change the gear oil,if so bet it stuck closed/on to close the circut
nope i haven't done it yet the snows made me put it off its been stuck on ever since i got it working lol ill take a look when the weather clears up i need to do a few jobs so ill get them all done at once are doppler break pads any good?
