yamaha dt neutral light stays on
my green neutral light stays on no matter what gear im in has anyone got any ideas?
The neutral wire is earthed somewhere on something. Or the switch is stuck.
Dissconect the switch and you will know
i like that ... somewhere on something i hate finding earths -.- ill try disconnecting the switch first
The switch is self grounding,only 1 wire comming out of it right?
did you pull it out to change the gear oil,if so bet it stuck closed/on to close the circut
nope i haven't done it yet the snows made me put it off its been stuck on ever since i got it working lol ill take a look when the weather clears up i need to do a few jobs so ill get them all done at once are doppler break pads any good?
