XT125R clutch problem
Hi
I have been tasked with sorting out a problem with my nephew's Yamaha XT125R. The problem is, a garage has had a look and didn't fix it and now I have been given the bike plus the bits of clutch in a bag. I think I have found the problem, its the push rod, it seems that the end is broken.
Does anyone have a breakdown on how to remove it or a workshop manual I could download.
Thanks
Hi steve" to remove the rod, i take it the clutch cover is off " remove presure plate- then the lifter[ mushroom] then use a long thin screwdiver to push it out,, :yeah:
Thanks Balckhat! Do you know if its in two peices with a ball bearing spliting the two.
