March 15, 201313 yr Does anyone know if the clock dampers on the XS 250,360,400 etc will fit an 400C. If so i'm after some.
March 16, 201313 yr Moderator yep, the SOHC are all interchangeable with very little design change. the custom variants have longer forks and 16" wheel with a longer swing arm. Have you got the dampers yet?
March 17, 201313 yr Moderator do its an rd 400c not an xs400c? didn't make that very clear tried HVC cycle?
March 18, 201313 yr Moderator Didnt post RD in the first post did I my apologies Drewpy. OK, may still work for you. If you can measure your clocks I can measure mine (that's CLOCKS, not Cocks)
March 19, 201313 yr Author I think the clock are the same diameter just the rev range on the tacho maybe different.
March 19, 201313 yr Moderator I think the clock are the same diameter just the rev range on the tacho maybe different. my xs400 starts to red line at 9.25k if that helps
March 19, 201313 yr Author my xs400 starts to red line at 9.25k if that helps Only if it effects the rubber dampers.
